As I mentioned in another thread, I found a NAPA brake light switch for my '58. For any future forum searchers, it's NAPA part number ECH SL169 (just under $8.00).
Now I need your help in locating the root cause for why I still don't have any brake lights. Here's what I know:
- New switch works. Old one was bad. Verified by multimeter.
- Brake light fuse is okay. Verified by multimeter.
- Red and white switch wire connectors produce a closed circuit.
- No 12-volt reading across red and white connectors.
- Turn signals work. Obviously, brake light bulbs are okay.
Why would a working switch with a closed circuit not show 12 volts? Why is my battery not talking to my brake light switch?
Prior to my old switch failing, I had occasional brake lights, which indicates 12-volt flow. What changed? All I did was install a new working switch.
I'm clueless. Gentlemen, I seek your wisdom and experience.
Thank you!
Dave
Thank you!
Dave
