68 400Hsp 4 Spd with A.I.R vacuum hoses connection. - NCRS Discussion Boards
  • Jack C.
    • September 30, 1992
    • 1090
    There are 3 hoses that comprise this setup besides the 3 hoses that connect the 3 carbs together. My question is: Does it make a difference which way the hoses are attached to second the tee? The hose coming off the smog pump should attach to the bottom of the tee (T) and the choke pulloff and carb vacuum to the other two legs (horizontal) of the tee. Would it make a difference in vacuum performance if the smog hose was connected to one of the legs first and not the down leg?
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
  • Jack C.
    • 1090
    Re: 68 400Hsp 4 Spd with A.I.R vacuum hoses connection.
    To the top.
    Jack Corso
    • John C.
      • January 1, 2005
      • 616
      Jack
      Function wise I see no reason why it would matter what port a hose was attached to on the T.
      John
      • Jack C.
        • 1090
        John. My thoughts exactly, however, would the smog pump be pushing or pulling vacuum out to the choke pull off and carb or reverse?
        Jack Corso
        • John C.
          • January 1, 2005
          • 616
          Jack
          The carburetor is the vacuum source. Any change in vacuum would come from this end of the system.
          John
          • Jack C.
            • 1090
            Thanks John.
            Jack Corso
            • Dale C.
              • November 1, 1999
              • 844
              Dale
