Joe, Allen and Tim...thanks for your response.
I decided to start a new thread more appropriately titled.....I am not trying to make this difficult but something is not right and I am concerned about function and safety as well as correct installation etc.
I purchased a reproduction idler arm w/sealed grease fittings which included seal boot, castle nut and cotter pin made in U.S.A. from a well know vendor/catalog. It does not have the correct GM numbers etc. 1964 Corvette non-power steering....all parts are new...complete steering assembly. I have checked all of the other vendor catalogs and it apears they all seem to be selling the same part.
Upon installation I discovered when I torque the castle nut (45 ft.lbs.), it runs up too far on the ball stud which makes the cotter pin not run through the castle slots (see photos). It seems that the ball stud is too long and/or the hole that runs through the ball stud for the cotter pin is not drilled in the proper location or the castle nut is wrong...although the nut seems to be correct.
I assembled it in this order:
ider arm, foam seal, plastic washer, relay rod, castle nut, cotter pin.
When the head and legs of the cotter pin was not falling withing the castle slots, I installed a larger cotter pin and it is "kind of" securing the nut.....this concerns me! (see photos)
Advice??? Can I install a washer or two in between the castle nut and the relay rod to cause the castle nut to sit lower on the ball stud which would in turn make the cotter pin slot line up? Would this affect safety when the steering system pivots every time it is turned. Should I try to find a "taller" castle nut? Has anyone else had this problem with the supposedly correct Made in USA idler arm?
Could someone send me the measurements of an original idler arm ball stud? The attached photo with the tape meaure is from the reproduction idler arm I removed which had zert fittings AND a lower rubber boot between the bottom of the idler arm and the relay rod which (I think) took up some "space".
Not trying to make a mountain out of a mole hill.....this could only happen to me!
Thanks in advance!
Thanks in advance!
