Fan clutch 1960 - NCRS Discussion Boards
Fan clutch 1960
  • Al E.
    • September 5, 2011
    • 313
    Fan clutch 1960
    Is this the real deal? I removed it from a box of stuff I had that came with the car. I am cleaning out the garage and I have to toss some stuffIMG_0886.JPG
  • Larry M.
    • January 1, 1992
    • 2700
    Re: Fan clutch 1960
    Originally posted by Al Edmonds (53783)
    Is this the real deal? I removed it from a box of stuff I had that came with the car. I am cleaning out the garage and I have to toss some stuff[ATTACH=CONFIG]38691[/ATTACH]
    Don't throw it away.
    Can't say for sure it is a 1960 piece, but it should be correct for just about any Corvette through 1967. There were two designs, and this is the Eaton (coil) one. Small blocks and big blocks had slightly different shafts. Can't see this feature to tell which one you have. These Eaton units were also ink stamped on the front to indicate date and whether BB or SB application. Your picture does not show this due to age. The other design was the Schwitzer (bar) design.
    If you can provide additional pics that would help. On the Eaton design, the fluid reservoir ends changed from retangular shape to trapazoid shape beginning in 1968.
    Larry
    • Al E.
      • September 5, 2011
      • 313
      Re: Fan clutch 1960
      Larry,
      tell me what photo you need. I have it here and i can snap a many more.
      • Larry M.
        • January 1, 1992
        • 2700
        Re: Fan clutch 1960
        Larry,
        Side shot, and also a shot of the other end (looking straight down).
        Can you see any faint ink marks on the face of the fan clutch that you already photographed??
        Al: Before I receive some comments/corrections from others, the Eaton style first appeared around 1960 or so..........therefore I do not think it is suitable for the earlier cars. My comfort zone is the mid-years. I frequently get corrected when I comment on the C1 cars.
        • Al E.
          • September 5, 2011
          • 313
          Re: Fan clutch 1960
          Larry,
          LOL don't worry about it. I get corrected everyday. My comfort zone is nothing..
          • David L.
            • July 31, 1980
            • 3310
            Re: Fan clutch 1960
            Al,
            Your fan clutch looks like the one I bought last year that was stamped "EATON CJ" and "L27G" (Nov. 27, 1966) and came with 18" 5-blade fan stamped "912239", "SC", and "L6" (November 1966) used on 1966-1967 Corvettes w/AC.
            Dave
            • Mike E.
              • February 28, 1975
              • 5140
              Re: Fan clutch 1960
              Clutch fans through 62 had a flat face without the ridge that yours shows. It is very likely correct for mid-years, however.
              • Larry M.
                • January 1, 1992
                • 2700
                Re: Fan clutch 1960
                Al:
                Looks like you are getting some good, additional information. To help decide if this is a BB or SB fan clutch, you need to measure the shaft length from the extreme end of the shaft flange to the boss for the fan blade attaching stud(s). If it is 1.8 inches, it is a SB application. If 1.5 inches, it belongs to the BB.
                Hope this helps. There are two or three guys who can restore these fan clutches and properly stamp them, if you want to have this done. Their names are in the DRIVELINE or in the archives. Or let me know if you cannot find this info.
                Larry
                • Al E.
                  • September 5, 2011
                  • 313
                  Re: Fan clutch 1960
                  Originally posted by Larry Mulder (20401)
                  Al:
                  Larry
                  Thanks Larry this was going to be my next question
                  • David L.
                    • July 31, 1980
                    • 3310
                    Re: Fan clutch 1960
                    Al,
                    My "CJ" clutch pictured previously measures 1 25/32" (fan mounting surface to water pump mounting surface.
                    Dave
                    • Robert B.
                      • December 1, 1999
                      • 56
                      Re: Fan clutch 1960
                      This is a picture of the Eaton fan I had restored by Fred Oliva for my 1960 270 horse engine:
                      Hope this helps!
                      • Al E.
                        • September 5, 2011
                        • 313
                        Re: Fan clutch 1960
                        [ATTACH=CONFIG]38707[/ATTACH]
                        Hope this helps!
                        Crap.. thats looks sweet. Although it looks nothing like mine. I was hoping I had the real deal.
                        • Ian G.
                          • September 3, 2007
                          • 1124
                          Re: Fan clutch 1960
                          But now you can sell it on eBay and get most of the money you need for the right one
                          • Al E.
                            • September 5, 2011
                            • 313
                            Re: Fan clutch 1960
                            I got the over spray on it when i was painting the blades. Maybe i should sale the blades with it. Not sure what its worth or how much the correct one cost. I looked at CC to find it but no luck. I bought one from autozone that works. I am happy but next year i plan to go for a flight.
                            This year i just want to drive and enjoy my car before i restore it to flight.
