1971 LT-1 Clutch Configuration - NCRS Discussion Boards
  • Scott V.
    • 42
    I am getting ready to replace the stock clutch in my 71 LT-1 and would like to know the correct configuration. I believe it is an 11" clutch with a fine spline (26 spline) pressure plate but want to validate. I understand the originals are no longer avaialble and have been told to go with a hayes replacement. Thanks.
  • Michael G.
    • January 1, 1997
    • 1251
    Re: 1971 LT-1 Clutch Configuration
    Scott,
    Yours would be a fine spline, unsure about diameter. I've been very satisfied with my LUK heavy usage clutch.....comparable to a Hayes Street/Strip clutch. Pedal touch is no heavier than a standard clutch. Got mine throught Carolina Clutch(?).
    • Scott V.
      • 42
      Michael - Thanks for the information. Carolina Clutch still lists LUK clutch kits and they are significantly less expensive than the Hayes.
        • 11643
        FYI - the last Hayes I purchased was a reboxed Luk.
          • 43219
          Scott-----
          Your application originally used a 26 spline, 11" diaphragm-type clutch with a 14" flywheel (unless you have one of the 8 ZR-1's built for 1971).
          Your best bet is to go with the LUK clutch for your application. That will give you the most stock-like performance available today. LUK is one of the major manufacturers of clutches in the world and makes many for the OEM's. Many C4 clutches were originally of LUK manufacture. I expect that C5 and C6 are, too.
            • 15599
            Scott-----
            The C6 Z06 & Zr1 clutches are Luk -- I saw the name on the shipping containers at the Performance Build Center in Wixom, MI. I can't speak to the LS3 engines. I haven't been to St Catherine's yet. It is on my bucket list, but so far it hasn't come together.
            • Michael G.
              • January 1, 1997
              • 1251
              Scott,
              Here is the link to the replacement clutch kit I used from LUK....purchased through Carolina Clutch.
              • Scott V.
                • 42
                All thanks for the information.
                Michael - Thanks for the link, quick question. I just got off the phone with Carolina Clutch and they do not show an application for the "Gold heavy duty replacement kit" for 1971 corvette. They do show a standard duty replacement 11" for the 454 and that would probably work but wanted to check before I ordered.
                • Michael G.
                  • January 1, 1997
                  • 1251
                  The only potential difference should be the clutch disc. In your case would need the 26 spline disc.....pressure plate would/should be the same. Most likely can make the request for the change to the fine spline disc.
                  Interesting note.....during my research contacted a tech at LUK for more info. He indicated most all 11" clutch discs as they're called are only 10 3/4", the LUK heavy useage disc is 11 1/8". Obvisoulsy giving the user more engagment on the fly wheel. Pressure plate and disc fits with NO clearance issues. Pedal pressure has been a non-issue.....smooth as butter. I did not use their supplied throw out bearing and chose to use a National self centering bearing.
