I am looking for some clarification on fasteners for the air cleaner. The AIM shows bolts and lockwashers going into the weld nut plate assemby and nuts and bolts for the lower bracket. The Judging Guide shows the same graphic as the AIM, states that nuts and bolts are used for the lower bracket, however goes on to state that the fasteners attaching the air cleaner to the inner fender are dished hex-head self tapping sheet metal screws with a seperate flat washer. What are the correct fasteners into the weld plate?
