Nose Body Panels - NCRS Discussion Boards
Nose Body Panels
  • Tony M.
    • August 31, 2010
    • 102
    Nose Body Panels
    Gentlemen,
    Hope you are all well!
    I would like to know if a document exists that shows all front-end body panels on a 59 Corvette. The reason I am asking is because I have not figured out how the panels make up the front nose panels. Every supplier has a different cut-out. The bonding strips are well defined except when it comes to the nose area.
    Thanks for the support!
  • Roger W.
    • January 29, 2008
    • 572
    Re: Nose Body Panels
    The Service Manual (ST-12) has a pretty good drawing on page 1-44. If you look at your car, you can probably figure out which bonding strip is which on the drawing.
    • Tom D.
      • September 30, 1981
      • 2151
      Don't know if or what you are planning to buy. This information should be known, in any case.
      Three or four years ago, I bought a top "Hood surround" for my 60 and got it installed and painted. Now I find the back side curvature of the front, where the round hole for the nose emblem goes, is too thick and/or too flat for the curvature of the clear plastic emblem's edges. (The right and left side edges, which fit under the fiberglass, are thicker than the top and bottom of this part.) Now planning to machine flatten the two side edges of the plastic part, in order for it to "come fully up into" the chrome bezel like it should.
      https://MichiganNCRS.org
      Michigan Chapter
      Tom Dingman
      • Tony M.
        • August 31, 2010
        • 102
        Roger,
        Thanks for the response...I have the Assembly Manual, Servicing Guide,Corvette Restoration Handbook and The Restoration and Technical Guide. Unfortunately no Service Manual.
        • Tony M.
          • August 31, 2010
          • 102
          Tom,
          What I may consider doing is replacing the bottom portion of the front-end. The portion that contains the turn signal along with bottom opening. The holes for the center chrome half bellow the teeth are oversized...due to a lower panel hit many years ago!!! Also a small crack just above the center bumperette fiberglass.
          Hope this is clear???
          • Philip P.
            • February 28, 2011
            • 558
            Here is the picture on page 1-44 of ST-12
            Phil
            • Tony M.
              • August 31, 2010
              • 102
              Philip,
              You are the best...thanks! Now here is my misunderstanding, I do not see the bonding strips between parts 22 and 24??? Technically, I only need part 24.
              Question: Are there or should there be bonding strips between these two parts?
              • Philip P.
                • February 28, 2011
                • 558
                Tony, It is kind of hard to visulize but item 23 is the bonding strip between panels 22 and 24. I tried to get a picture of mine but could not get anything clear. I am not sure how to explain it but it appears to go along the lower panel up the side of the grill opening onto the front below the headlight. That should make it very confusing.
                You can see the bonding strip a little better.
                Phil
                • Tony M.
                  • August 31, 2010
                  • 102
                  Philip,
                  I have a Bonding strip 23 in my hands since I needed to add it on my 59 Drivers side. This strip literally hugs the inside fender right next to the signal lights. It is literally on the outside of the grill opening. I do not think that this is what bonds 22 and 24.
                  PS: I checked the passenger side, area between 22 and 24...no strip and very clean????
                  Still confused!
                  • Philip P.
                    • February 28, 2011
                    • 558
                    Tony, I will try to get some pictures of the way these are attached may take a little while. It may just be flanges on each piece that are bonded together.
                    Phil
                    • Philip P.
                      • February 28, 2011
                      • 558
                      Tony there is some type of bracket between the front piece and the one below the head lights. I do not see it in the diagram of the ST-12 but here is a picture of my car
                      Phil
                      • Tony M.
                        • August 31, 2010
                        • 102
                        Philip,
                        You are the best!!!!
                        The picture is bonding strip 23. This strip connects the inside panel with the front nose.
                        I am wondering if the above part nu PFG-109 from Zip is the original front piece??? Frontnose.jpg
                        • Philip P.
                          • February 28, 2011
                          • 558
                          Tony, I looked at it not sure but it may be one piece so it would be easier to install but not correct from what I can tell. I would give them a call and see. Some of the suppliers have the separate pieces. From the ST-12 pictures there are 3 pieces plus the bonding strips.
                          Happy to help
                          Phil
                          • Philip P.
                            • February 28, 2011
                            • 558
                            When I said easier to install that is in the mind of the installer, fiberglass is its own animal, I did quite a bit in the early sixties and we repaired what was there with mat and resin. THe one piece in my opinion may be easier as you would eliminate some of the seams.
                            Phil
                            • Richard M.
                              Super Moderator
                              • August 31, 1988
                              • 11367
                              Tony,
                              If you go to Sermersheim's website.....Here, you can download their pdf catalog. There are some crude diagrams there that may help. The strip is item #27 on Page 2 of the catalog. Also as Phil's diagram picture is items 1 & 23 as mentioned.
                              I used a one piece nose on a '59, but bought those bonding strips which are to attach the inner skirts to the nose. It also has a flat area at the bottom which is where the lower center valence mates with the sides. The picture below shows these on the skirts before the nose went on. In my case, being a one-piece, that area at the bottom(where the lower spring clamps are) got bonded to the lower front valence. Also as seen in Phil's photo above of the same area, which looks like the passenger side.
