I am restoring a 1964 L76. I have replaced the clutch & flywheel and tracked down bellhousing 3788421. I did have bellhousing 3872444 installed, which I think is correct for 65 or 66. When I went to bolt the engine and tranny together, I noticed the opening on the 3788421 bellhousing does not fit over the housing and bolts that hold the tranny shaft.
I'm wondering if the 3840383 bellhousing has a larger opening.
The tranny is a muncie 4 speed. If the bellhousings have the same size opening, is it possible the tranny is from a later year and had a larger housing around the shaft?
Thanks in advance for any help. I'm hoping there is a solution that does not include tracking down a 1964 muncie 4-speed to replace the one I have.
