65 L78 Holley fast idle assembly - end missing??? - NCRS Discussion Boards
  • Gary C.
    • April 1, 1998
    • 380
    Gents,
    does anyone know if the fast idle lever is the same on all 4150's or is it special to the L78 List 3124 Holley?
    Mine has the end missing, see below?
    Dont know what happened to it and I would like to replace it!
    Gary
    Perth West Aust.
  • Timothy B.
    • April 30, 1983
    • 5199
    Re: 65 L78 Holley fast idle assembly - end missing???
    Gary,
    Looks like your missing the bottom ball on the lever. It's probably the weight that holds the lever down so the idle returns to normal when the engine warms. I don't see why it would be different than any other models. Better check with Chicago Corvette Supply or call Holley to ask.
    • Clem Z.
      • January 1, 2006
      • 9427
      it is holley part # 45-376 but the color will be red
      • Wayne M.
        • March 1, 1980
        • 6414
        Here's the red fast idle cam off an original '64 LIST 2818 (no dash-1), dated 3_A_3. Had to JB-Weld the arm on this one . Look closely and you can see a cast "2"; don't know what this signifies. Per P&A catalog (Rev July '65), this should be Gr 3.766 #3852479. In 1965 MY, with the dash-1 (somewhere around 4_8_x) takes 3867994, which I would assume would be a different color. For the L78 LIST 3124, the catalog says # 3669147.
