54 Brake Master Leaking - NCRS Discussion Boards
  • Cathy S.
    • August 31, 2003
    • 293
    I have an original brake master cylinder. Its been rebuilt and working fine. It seems to leak from around the cap-original cast cap. I put two cork gaskets on and it helped for a while. I've been filling the master to about an inch below the bottom cap threads. Too full? Its just making a mess and dripping on the firewall.
  • Chuck G.
    • May 31, 1982
    • 2039
    Re: 54 Brake Master Leaking
    Are you sure it's leaking from the cap?
    How about the fittings in the front?
    Chuck
    • Cathy S.
      • August 31, 2003
      • 293
      Definitely leaking from around the cap.
      • Gary C.
        Administrator
        • October 1, 1982
        • 17940
        Cathy, might try sealing it with Fuel Lube sealer. Any aircraft supply house will have it. Gary....
        NCRS Texas Chapter
        https://www.ncrstexas.org/
