68 Door Panels - NCRS Discussion Boards
68 Door Panels
  • Cathy S.
    • August 31, 2003
    • 293
    68 Door Panels
    My original panels are sad. Who makes the best dare I say repros?
  • Michael D.
    • June 30, 1996
    • 536
    Re: 68 Door Panels
    Probably Al Knoch.
    • Mark D.
      1984-86 Team Leader
      • June 30, 1988
      • 2152
      Re: 68 Door Panels
      Cathy,
      For an extra charge, Al will make shark door panels with the original backing board.
      If the car is gonna be judged, don't forget the vapor barriers.
      Kramden
      • Dick W.
        • 10483
        Re: 68 Door Panels
        To my knowledge no one repos the early version. Al would be my vendor of choice.
        Dick Whittington
        • Russ T.
          • May 31, 1989
          • 113
          Re: 68 Door Panels
          I just installed a new interior in my '68 convertible from Corvette America.
          I was pleased with the quality, inventory and service. They also blasted my
          seat frames and re-built the seats with new foam, etc. No problems, everything
          looks great.
          You may want to check them out. They have a wide variety of products and a nice catalog.
          Russ Trotter
          NCRS #15044
          • Michael M.
            • June 30, 1997
            • 97
            Re: 68 Door Panels
            Corvette America puts a lot of R&D into their products. I've taken a tour of their plant (Pa. Made in America!). They take a lot of pride in their products they make. Switched from Al K to them based upon fit, finish, ease of return if needed etc. based upon previous purchases.
            Don't have a horse in the race just an opinion. As with anything, we all care for different vendors based upon the good bad and the ugly.
            • Cathy S.
              • August 31, 2003
              • 293
              Re: 68 Door Panels
              I received my CA panels today. Look beautiful fit is awful. The original panels are contoured the CA panels are straight. Put one corner on the opposite corner is 2" off the door. I would really have to bend to fit. I'm sure if I bend as much as needed the vinyl will separate from the back board. Boy am I sorry I didn't buy AK.
              • Brandon T.
                • October 23, 2008
                • 872
                Re: 68 Door Panels
                I would send the door panels back to CA and get some from AL K.
                • Ron G.
                  • December 1, 1984
                  • 865
                  Re: 68 Door Panels
                  I don't judge interiors, but it has been my experience that Al Knock's panel's seem to have more of a correct grain and give to them as oppposed to the other after market products. Even as good as Knock's are, they do not 100% resemble the factory originals. Just a suggestion, that if your panels are some waht restoreable, they can be repaired and restored to look as new. There is a guy here in Connecticut that does an awsome job including reincorpating the grain. Something to think about as I always prefer restoring an original rather than using a reproduction.
                  "SOLID LIFTERS MATTER"
                  • Charles P.
                    • February 14, 2012
                    • 24
                    Re: 68 Door Panels
                    I recently used CA panet in my coupe. As someone said in an earlier post, the fit was horrifying. Shortly after installing them, I met a gentleman at the Houston Corvette Expo and he had the same problem putting them in his Top Flight car. He said he had to "shave" the back side a little at a time to take the "rocking from top to bottom" out and the top and bottom to touch at the same time. If I had to do it over again, I'd try Al's.
                    Charles Prejean
                    '68 L79 Coupe
                    • Cathy S.
                      • August 31, 2003
                      • 293
                      Re: 68 Door Panels
                      I placed an order with AK. Boy I hope his are better.
                      • Cathy S.
                        • August 31, 2003
                        • 293
                        Re: 68 Door Panels
                        Received my AK panels today. What a difference. Fit and quality is perfect. Thanks Al!
                          • 3416
                          Re: 68 Door Panels
                          Hi Cathy,
                          Did you buy the panels with the abs or fiber-board backing?
                          If the fiber-board, I'm curious about the cost.
                          Thanks!
                          • Cathy S.
                            • August 31, 2003
                            • 293
                            Re: 68 Door Panels
                            I went with abs. I did not inquire about the fiberboard.
                            • Mark D.
                              1984-86 Team Leader
                              • June 30, 1988
                              • 2152
                              Re: 68 Door Panels
                              Alan,
                              A buddy of mine bought some black door panels with the fiberboard backing for his 69 from Knoch. That would have been about a year ago and, I think, they were $585.00 each.
                              Mark
                              ADD: He paid $1106.25 total.
                              Kramden
