Missing torque spec? - NCRS Discussion Boards
  • G A.
    • February 18, 2010
    • 229
    Looked through the Chassis Service Manual amongst others with no luck.
    I'm searching for the torque spec for the two bolts that attach the tie-rod support arm (steering knuckle) to the spindle. They have stover nuts and one is 2 7/16, the other is 2 5/8 inches long.
    Dan
  • David H.
    • June 30, 2001
    • 1559
    Re: Missing torque spec?
    Dan
    70 fl. lbs. for my 1980 (page 3C-21 of Shop Manual under "Steering Arm Nuts")
    Here is a link to a Van Steel pdf suspension specs on page 9.
    • G A.
      • February 18, 2010
      • 229
      Thanks David. I also finally found some more info in this thread, https://www.forums.ncrs.org/showthre...08-torque-spec.
      Dan
