C2 1966 Half-Shaft Orientation? - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2137
    A friend has lost track of which end is which, on his 1966 half shafts. Does it really matter which end of the half shaft installs by the wheel?
    Or... which end is at the differential? The U-joints are not yet installed.
    Thanks!
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: C2 1966 Half-Shaft Orientation?
    No Matter.
    • Larry M.
      • January 1, 1992
      • 2701
      No Matter.
      Agree with Wayne. Tell him to take his pick. Unlike the driveshaft, the half-shafts were also NOT balanced due to their relatively low rotational speed. So there should be no balance weights to consider. I also believe, big block half-shafts were shot-peened for additional strength/stress relive. But again, this doesn't effect their orientation.
      When installing the U-joints, tell him to be very careful, or use a special machined block for strength, to avoid bending the spindle flange. These HD metal blocks can be made or purchased. Or have a Driveshaft Company install these u-joints.
      Larry
      • Wayne W.
        • April 30, 1982
        • 3605
        Larry
        Or just use the flange on the axle.
        • Ron G.
          • December 1, 1984
          • 865
          As all our conterparts made mention, it does not matter which end of the half shaft goes to what end. All big blocks and LT-1's half shafts were shot peened, but I would be interested in knowing if the L-79 350 H.P. and the L-76 365 h.p. cars were shot peened. Although I am primarily a 68-72 enthusiast with emhasis on LT-1's, I have owned several 66-67
          L-79's, but never knew to look as the we were not aware of some models having their half shafts shot peened.
          "SOLID LIFTERS MATTER"
            Ron -
            On midyears, only the big-block half-shafts were shot-peened.
            • Ron G.
              • December 1, 1984
              • 865
              I told you I did not know, but now I do. Thanks John.
              • Philip C.
                • December 1, 1984
                • 1117
                When was the last time you pulled a hard hole shot? Phil 8063
                • Ron G.
                  • December 1, 1984
                  • 865
                  Phil,
                  With the Corvettes, not in a long time. With my GTO, a couple of weeks ago.
                  - Ron
