early 1967 steering column - NCRS Discussion Boards
  • David P.
    Infrequent User
    • September 1, 2011
    • 2
    Pease help i am cofused about the lower plastic collar & spring set up,i need some advice -help (607) 2727576 N.Y dpochily@twcny.rr.com thanks Dave
  • Ara G.
    • January 31, 2008
    • 1108
    Re: early 1967 steering column
    David,
    Welcome to the NCRS...I see that you are a newer member based on your membership number. It would probably help if you actually indicate what your questions are or advice sought in your post. Lots of very knowledgeable guys on the forum will help you, but you really need to let us know what the issue you are having is. Some members work during the day....and can check periodically during the day on the computer.....but can't just grab the phone and call you. You'd be surprised at how quickly some members will get back to you, but let them know what your problem is so that they can help...
    Welcome aboard.....
    ARA
    • Al R.
      • June 30, 1988
      • 688
      David, if you will do a check on past articles, there is at least 1 excellent 1 on the rebuilding of the steering columns on 67, both the tele & the standard. with a breakdown illustration of them that might help. I just rebuilt my 67 column approx 2 weeks ago with the help of it. I also had to contact the author on 1 question I had. Hope this helps.
      • David P.
        Infrequent User
        • September 1, 2011
        • 2
        Thanks to every ones replies & help i believe i have a early column that missed the service bulliten, the plastic lower tention collar with the acme type thead? again thanks to all Dave (53761). it was built sept. 66
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11345
          Dave,
          See this thread. Jim Shea has a nice diagram in post #6, and there are some photos of a early 1967 standard column I restored (november car) there in post #10.
          Rich
          https://www.forums.ncrs.org/showthre...581#post592581
