1967 Windshield Wiper Parked Position - NCRS Discussion Boards
  • Jeff B.
    • April 30, 1980
    • 169
    When the wipers are in the parked position, which one is parked on the bottom, the driver side or passenger side?
    1967 Coupe 427-390 w/air
  • Michael M.
    • February 1, 1993
    • 605
    Re: 1967 Windshield Wiper Parked Position
    Jeff, at rest the passenger side wiper folds over the driver side and both are parallel to one another.
    • Peter L.
      • May 31, 1983
      • 1930
      Jeff - In addition to Michael's reply see UPC 1 ASM, SHEET D5 of the 1967 Corvette AIM. Pete
      • Ralph P.
        • February 1, 1990
        • 253
        What's the best way to adjust these wipers? What's the purpose of the screw on each wiper arm?
        • Michael J.
          • January 27, 2009
          • 7167
          You have to use the tool and pull the arm off the shaft and readjust on the multi-tooth slots.
          • Peter L.
            • May 31, 1983
            • 1930
            Ralph - In addition the adjustment mentioned by Michael, the screw on the side of the wiper arm body can be used in the final adjustment to adjust the position of the rod, i.e., the piece that the wiper blade assembly attaches to, so the wiper blades don't "kiss" during operation and when moving to the rest position. Take care when making the final adjustment because the 67 wiper blade assemblies are not very robust and might end up bending if they "kiss." Have fun. Pete
