mid year power brake booster ID help - NCRS Discussion Boards
  • Keith B.
    • March 7, 2008
    • 928
    I located what appears to be a mid year booster. the only problem I can't find any of the numbers found in the archives on the booster. the only numbers I found were "221" on the one tab facing the front, and on the rubber boot for the M/C rod of 542867. does anyone know what I found
  • Bill M.
    • April 1, 1977
    • 1386
    Re: mid year power brake booster ID help
    This is on one tab of my '65 booster:
    This is on the other tab:
    • Russ S.
      • April 30, 1982
      • 2163
      221 is the 221st day of the year.
      • John M.
        • January 1, 1998
        • 813
        Kieth,
        I think the 7011 is the last 4 digits of the part no. Someone will confirm.
        JB
        • Russ S.
          • April 30, 1982
          • 2163
          Originally posted by John McRae (30025)
          Kieth,
          JB
          John is correct- last four digits of the part number
          • Keith B.
            • March 7, 2008
            • 928
            yes I under stand a four digit number is the part number. but this booster I am looking at DOES NOT have any four digit numbers stamped into it. only the date code
            • Page C.
              • February 1, 1979
              • 802
              did you check the backside of the tabs?
              • Keith B.
                • December 1, 1991
                • 397
                The date codes of 67s were on the front and the part number on the rear of the tab. These units were specific to 67 only. The 65 and 66 were a different part number as noted above and the date was on the rear and part number on the front.
                Keith Burmeister
                • Keith B.
                  • March 7, 2008
                  • 928
                  Yes cleaned off both sides of both tabs and only date stamp.
