C1 Front Crossmember to Frame Bolt Torque spec - NCRS Discussion Boards
  • John L.
    • February 1, 2005
    • 207
    What is the correct torque specification for the 16 bolts/nuts that attach the front crossmember to the frame on a 1954? Also is there a specification for the 4 bolts that attach the front thrid arm bracket. Did not want to strip any threads in the cast piece....
    John Lanning
  • Gary C.
    Administrator
    • October 1, 1982
    • 17971
    Re: C1 Front Crossmember to Frame Bolt Torque spec
    John,
    Didn't see any torque specs in the ST12. The bolts are 3/8 inch Grade 2. You might check for torque specs on a Grade 2 bolt/nut.
    Might send Tom Parsons an email.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Dennis C.
      • June 30, 2002
      • 888
      John,
      I can't speak about a 1954, but the 1961 AIM indicates 15 - 20 lbs ft for the crossmember bolts.
      Dennis
      • John L.
        • February 1, 2005
        • 207
        thank you for the information ..... was able to find most of the remaining torques on the front end but this was the one I could not find. Now i can finsih this Up...
        Much appreciated!!!
