1970 door outer window wipe staples - NCRS Discussion Boards
  • Terry B.
    • April 1, 2003
    • 50
    Does anyone know of a source for door outer window wipe staples. I am re-skinning my original door panels and would like to keep the wipes original using staples vs rivets.
    Web Master Miami Valley Chapter 2010 to present
    Newsletter Chairman Miami Valley Chapter 2003 to 2011
    Events Chairman Miami Valley Chapter 2010
    Miami Valley Chapter Secretary 2012 to 2015
    Miami Valley Chapter Media Chairman 2016
    Miami Valley Chapter Judging Chairman 2017 to present
    • 3422
    Re: 1970 door outer window wipe staples
    Hi Terry,
    Re-skinninig!!!!! I'll be interested in seeing your results!
    Dr. Rebuild sells staple sets for the 68-72 steel shroud seal. I'd think they'd be suitable for the door panel too.
    I'd also think you could buy a length of music wire from a hobby shop, and cut and bend your own.
    Good Luck!
      • 11698
      Best of luck with that one. The one (1) time I saw that on a car was at a Regional at Carlisle, PA. The skin sagged off the dash and door....
      Make sure you use good adhesive.
      Patrick
      • Terry B.
        • April 1, 2003
        • 50
        Alan, Thanks for the reply. I'll try Dr Rebuild. If results turn out good, I'll send you a picture
