What is the best way to loosen metering blocks from the main body of the carb? What should I use to soak it in that will not remove the finish to the main body or the metering blocks?
carb metering block removal
Re: carb metering block removal
might help if you were to clarify just which version of the metering block you are referring to. If it is a Holley with the metering block that is held on by the float bowl, a sharp rap on the side of the block with a soft faced hammer should do the trick If it is a secondary block held on with the funny-looking screws, remove the screws and peel the gasket, the block should come with the gasket that is under it.Bill Clupper #618- Top
Sorry, it is a 2818 holley so the prim and sec blocks are held on by the float bowls. I have tried a light tap with a rubber hammer after soaking with WD40 and tried a small flat blade screw driver around the side but neither of them want to budge. The carb has been sitting in a dry storage shelf for 30 years and all the other parts came of fairly easy.- Top
- Top
