Early 67 vacuum advance control - NCRS Discussion Boards
  • Joseph M.
    • June 30, 1999
    • 334
    I have an early 67 390. What is the correct vacuum advance control for this motor? I've seen 355 and 360. Tx.
    • 43248
    Re: Early 67 vacuum advance control
    Joseph------
    If you have distributor GM #1111247, then you should have a GM #1115360 vacuum control.
    • Wayne M.
      • March 1, 1980
      • 6414
      Per Delco test spec book, only the early 390hp [non-K66] # 1111141 (1966 carry-over) should have the 1115355. Have no ideal where the VIN break point is.
