Steel wheel markings - NCRS Discussion Boards
  • William S.
    • March 1, 2002
    • 55
    Can someone tell me about the markings on this wheel and if it will judge OK as a spare for my 65?
    Thanks for your help.
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Steel wheel markings
    Bill -- yours looks OK for me. Here's one of mine with a '65' and a '3' for the month. Of course, the inside of the air chamber cannot judged, but your stampings probably indicate that the external features will be OK. Like a 'GM' stamp on one of the spiders (between the bolt holes) and the two 'nubs' by the valve stem, and absence of any stampings either side of the valve stem hole.
    y
    • David L.
      • July 31, 1980
      • 3310
      William,
      It appears that your wheel is stamped with a "5" and a "66" (May 1966) and is an original 1966 Corvette wheel. The 1965 and 1966 Corvette wheels made from the Fall of 1964 to 1966 are the same (GM # 3869156). However, I one once owned an "early" 1965 Corvette wheel dated "12" and "64" (Dec. 1964) that was riveted instead of welded.
      GM # 3869156 service wheels made in 1979 & 1980 (and probably earlier) have stampings near the valve hole.
      Dave
