Guys;
I have a situation which I have never run into before... and I am not quite sure what to do next.
I just finished some upgrades to my L78.. some for more judging points the others for better drive-ability.. the judging point stuff include a water pump/pulley/fan clutch replacement and is not the issue here.
The drive-ability changes included: replacing the base of my "dated" carb with the one off my service replacement so as to get manifold vacuum versus ported vacuum; replacing the TI coil with a "correct" reproduction from TI Speciality; and installing an adjustable VAC so as to get to that 2" rule which we all know about (I'm running a non-stock cam so idle vacuum is lower than spec)...
Here's the problem... The car will run after initial start up although I cannot get it to run at high idle upon start-up although the high idle cam is set.. I can drive the car and it will drive just fine.. decent idle and nice power... the car will run fine for as long as I do not shut it off... If I do shut it off it will not start again and appears to be flooded. If I hold my foot to the floor and crank it (the thing to do for a flooded engine) it will backfire up through the carb.... big time... Yesterday I got a major explosion out of it... scared the crap outta me! If I let the thing sit and fully cool off it will start and run again.
Can't be very many things because I have not changed many things..... I don't have much experience with Holley carbs... Could this be a power valve issue?
I appreciate any thoughts....
Joel
Joel
