C-1 Tach removal - NCRS Discussion Boards
C-1 Tach removal
  • Tim S.
    • July 31, 1995
    • 18
    C-1 Tach removal
    c-1 I need to remove the tach from my 61 to return it for servicing. I recall a post or Restorer article with a good step by step set of instructions, but I can't find it. I know its a tedious job, but I don't want to destroy any of the other instruments in the process, so I'm willing to take the time.
    Anyone have the article or a good checklist for the job?
  • Philip P.
    • February 28, 2011
    • 558
    Re: C-1 Tach removal
    Do you have the ST-12 it spells out how to do it in sections 1 and 12, basically you need to remove the insturment panel and all that is associated wires. I do not know of ay other way to get the tach out.
    • Bruce B.
      • May 31, 1996
      • 2930
      I have had good luck by just removing the nuts that hold the 2 separate gauge pairs in the housing and moving them back before removing the gauge cluster so the tach can then be removed.
      Disconnect your battery before doing anything.
      • Don E.
        • April 30, 2005
        • 66
        Tim, This is a link to a step by step approach to removing the dash cluster. In short, the who cluster will need to be removed from the dash, to gain access to the Tach. https://www.forums.ncrs.org/showthre...1+dash+removal
        Don
