54 thermostst temp - NCRS Discussion Boards
54 thermostst temp
  • Guy M.
    • November 1, 1993
    • 500
    54 thermostst temp
    I stsrted out with a 160 degree thermostat because the engine is bored at 40 over and it runs steady at that temp. Should I run the 180 as the manual indicates. Are there reprocushions running 160 as opposed to a 180. Burning issues? Thanks as always
    • 43291
    Re: 54 thermostst temp
    Guy------
    I always recommend using the factory-specified thermostat (except for later 195 degree-equipped C2 and C3 cars).
    • Chris S.
      • January 1, 2000
      • 1069
      there are some that would argue......that lower temp will not get the oil hot enough to burn off impurities, water, etc.....
      It is oil temp that matters IMO.
      I have a 180 in mine
      what are you going to do with the car? drive or trailer queen
      1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
      Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
      1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
      1957 Corvette - FI 3 sp - Black and Silver
      • Guy M.
        • November 1, 1993
        • 500
        No trailer queen here, im going drive this sucker. When I take the radiator off for body drop Ill put a 180 in. Im sure there are good reasons for it or it wouldne be speced. Thanks Chris for all your input.
