54 pinion seal - NCRS Discussion Boards
54 pinion seal
  • Guy M.
    • November 1, 1993
    • 500
    54 pinion seal
    My seal is seeping, I have a seal I purchased a couple of years ago. The manufacturer is National, #3588, ( I think, its not stamped too deep) measurers 3 7/16 OD and the metal portion measurers 1 7/8 I.D. Is this the correct seal??? Thanks as always.
    • 43219
    Re: 54 pinion seal
    Guy-----
    The dimensions sound correct. However, I cannot find any reference for a National #3588.
    The 53-55 Corvette pinion seal is different than later C1. It was discontinued without supercession in 1971 and was GM part #3707355. Caution: I believe many of the manufacturer cross-references for this part number are INCORRECT.
    • Willard M.
      • August 31, 1979
      • 422
      Re: 54 pinion seal
      Mine started leaking this winter. I planned to buy the seal from CC or Grossmuellers. I think it is $46.00.
      • Willard M.
        • August 31, 1979
        • 422
        Re: 54 pinion seal
        I was too quick to post. I should have asked about the procedure to replace it. Is this a task for a backyard mechanic or should I pass it on to my mechanic? Bill
        • Guy M.
          • November 1, 1993
          • 500
          Re: 54 pinion seal
          I know CC sells a C1 seal but I dont know if it works on 53-54. Seems 54 is unique to later models.
          • Dick W.
            • 10483
            Re: 54 pinion seal
            CR cross reference Their pt. no. 17727
            Inches
            Shaft 1.739
            Bore 3
            OD 3.006
            Width 0.5
            Dick Whittington
