67 427 power glide kick down linkage - NCRS Discussion Boards
  • Keith B.
    • March 7, 2008
    • 928
    does it interchange with any other GM car. the one I have the one ball and socket joint is loose. also with the dipstick be the same on any other GM cars. thanks
  • Russ S.
    • April 30, 1982
    • 2162
    Re: 67 427 power glide kick down linkage
    From my experience when I was looking for my pcs, I don't think they do interchange although there are parts of them that do such as the belcrank. I don't think the linkages do. LI corvette does have what you need.
      • 43212
      Keith------
      The upper rods are unique to Corvette (and also different for L-36 versus L-68).
      The bracket assembly (with "bellcrank") is common to all 67-68 passenger, Chevelle, Camaro, and Chevy II with Powerglide.
      The lower rod is common to 65-68 passenger car with big block and Powerglide and also common to 65-68 Chevelle with big block and Powerglide.
      The dip stick is common to 1965-66 passenger cars with big block.
      There is no utilization of any of the above parts for other GM cars.
      • Keith B.
        • March 7, 2008
        • 928
        Thanks Joe
