1963 front bearing retainer 63 - NCRS Discussion Boards
  • Joe T.
    • December 1, 2000
    • 131
    Can anyone tell me who supplies the correct small front bearing retainer for 63 Muncie trans that goes with the 421 bellhousing? Thank you, Joe
  • Joe R.
    • July 31, 1976
    • 4551
    Re: 1963 front bearing retainer 63
    Well Joe, I believe that the nearest junk yard might be where to start. Or maybe a swap meet! Don't think anyone (China men included) will make a one year only part BUT they are on all Chevy's and Chevy II's. Anyway around here, originals are your only source!
    JR
    • Michael F.
      • June 4, 2009
      • 291
      Ebays a great place to start. Heres an example. http://www.ebay.com/itm/ws/eBayISAPI...vip=true&rt=nc
      Keep an eye out there will be more listed I am sure. Quite often well established sellers can tell you when they will have more. Or they can locate it for you. Many ebay sellers are top notch.
      • Timothy B.
        • April 30, 1983
        • 5196
        Michael,
        That ebay bearing retainer is not correct for a small hole 1963 bellhousing. I think that part # retainer is 4 11/16" diameter and the 1963 bellhousing #421 needs a 4 3/16" retainer. They do come up now and again on ebay so keep looking.
        • Michael F.
          • June 4, 2009
          • 291
          I didn't recognise the part number. It was already sold. I was just going by the ad heading.
          Just wanted to show the OP how easy it can be to find parts on the net.
          I am running the original "421" bellhousing in my 63.
          • Tim S.
            • May 31, 1990
            • 711
            I would suggest Tom Ambrose. I just purchased the front bearing retainer for my 63 T10 from him. Very helpful! His number is (847) 251 8375. He advertises in the Driveline.
            Tim
              • 43247
              JR
              JR------
              As far as the original ALUMINUM retainer goes, it was a one-year-only piece. However, as far as the cast iron replacement for the original retainer, it was anything but a one-year-only piece. It was originally used for many 1940 to 1954 Chevrolets and Chevrolet trucks.
              The 1963-only aluminum retainer was a REALLY DUMB one-year-only idea. The cast iron replacement was far superior.
              • Timothy B.
                • April 30, 1983
                • 5196
                Joe,
                I would love to know the GM mindset for use of a aluminum part for a bearing retainer that a throw out bearing has to ride on. If the cast part worked for other T-10 transmissions and chevrolet models what the ---- was this change all about..
                • Joe T.
                  • December 1, 2000
                  • 131
                  you were correct, he had the retainer and it is on the way. do you know i the actual bearing is available at autoparts or transmission garages or is it also hard to find?
                  • Joe T.
                    • December 1, 2000
                    • 131
                    do you know if the actual front bearing is available commercially for the 63 muncie with the 421 bellhousing and if so where? can I just get this at a transmission shop?
                    • Timothy B.
                      • April 30, 1983
                      • 5196
                      Joe, Call Larry Fisher at D&L transmissions he will have all the parts you need and he is a great guy. His number should be in the archives or google for the info.
                        • 43247
                        Timothy and Joe------
                        www.muncie4speed.net
                        If Larry doesn't have it or know where to get it, it cannot be gotten.
                        While I highly recommend that you contact Larry for the part, if time constraints are an issue, any bearing supplier that can cross reference from New Departure-Hyatt number ND47207 will get you what you need. However, they won't be able to supply you with most of the other parts you may need: Larry can.
