Gm rotor # 1852722 ? - NCRS Discussion Boards
  • Jim R.
    • June 30, 2001
    • 643
    Never new this, In the driveline this is listed as a extended tip rotor for hi rpm performace for the 60's gm engines, what do you guys know about this and how much of a difference will it make if your car has the standard tip not extended.
    JR
  • Joe R.
    • May 31, 2006
    • 1822
    Re: Gm rotor # 1852722 ?
    Jim,
    I seem to have a vague recollection of a Restorer article on this subject in the last few years. I think Bill Clupper was the author.
    Joe
    • Jim R.
      • June 30, 2001
      • 643
      Joe, I will look back in my restorer mags today to see if I can find that article, the nov-dec 11 driveline page 97 is where I had first learned about this K&B rotor. Jim
      JR
      • Wayne M.
        • March 1, 1980
        • 6414
        I bought one of the K&B rotors at Carlisle, last summer. Haven't tried it out yet. I'm surprised they're using the GM part # 1852722 in their description. Here's two D426R's I bought over the last decade; one in unopened box, which I assume is also white plastic. I'm thinking that this is the V8 service rotor for many years (began sometime after 1970, anyway). You C3 guys: were they TFP to 1974 ?
        Any problems using with a distributor cap with the "R" ? [I'm thinking of the Delco Patent 2769047], which is where I'm presently running the white D426R.
        • Gene M.
          • April 1, 1985
          • 4232
          From what I can measure, there is about .052" difference between the later one as compared to the extended version.
          • Dick W.
            • 10483
            Originally posted by Joe Raine (45823)
            Jim,
            Joe
            Think it was Bill Sangrey
            Dick Whittington
              • May 31, 1974
              • 8382
              Buy the accell rotor.its right on and cheaper.mike
              • Joe R.
                • May 31, 2006
                • 1822
                Jim,
                Did you find the article? If not, I would recommend sending an email to Vinnie Peters. I imagine he can email you a copy of it.
                Joe
                • William C.
                  • May 31, 1975
                  • 6037
                  I believe '74 was the first year for the white rotor, but for several years before that, Delco had a black rotor with an "E" stamped on it, also a POS with a shortened tip.
                  Bill Clupper #618
                  • Timothy B.
                    • April 30, 1983
                    • 5186
                    Bill,
                    Refresh my memory, what's the purpose for the shortened tip rotor and did the E stand for emissions?
                    • Ken A.
                      • July 31, 1986
                      • 929
                      Actually it's not. See the article in July 2011 Auto Enthusiast. An "old" Accel rotor was close, but not the current stuff.
                      • William C.
                        • May 31, 1975
                        • 6037
                        Supposedly it had the effect of raising the system voltage to fire the charge. Unfortunately (at least to a poor dumb ME) it doesn't make any sense from an e=ir standpoint as the 12v system energy doesn't really change it's energy capacity, and the rather abysmal results when one is used in an 11-1 compression engine would seem to verify my analysis on that point.
                        Bill Clupper #618
                        • Jim R.
                          • June 30, 2001
                          • 643
                          Found it Joe, volume 36 number 1 summer 2009, Run The Redline by Bill Clupper.
                          Jim,
                          Joe
                          JR
                          • Jim R.
                            • June 30, 2001
                            • 643
                            I looked to see what I had put in for a rotor in my 65 327 I have MSD #8467 I wonder how this one compares .
                            JR
                            • Paul H.
                              • September 30, 2000
                              • 682
                              Haven't measured them but I must agree with Mike. My cars could not run better than they do with the Accell rotors. I also like their points.
