C1 Hardtop quarter window dating -- on the inside or outside of window? - NCRS Discussion Boards
  • Peter R.
    • June 19, 2011
    • 233
    My old windows have no dates--evidently they are old replacements. I'm getting new replacements with dates; I ordered a pair, but received only a single window. I don't know if it's a left or a right because I don't know if the date should be on the outside or inside (and the judging manual does not specify) surface of the plexiglas. Can someone tell me whether the date and other markiings are on the inside or outside of the hardtop quarter windows?
    Pete
    Pete
    1954 Corvette #814
    1957 Corvette #646 -- FI, 3-speed
  • Chuck L.
    • July 31, 1996
    • 260
    Re: C1 Hardtop quarter window dating -- on the inside or outside of window?
    Pete, Mine were on the inside on my '62 hardtop. Just saw your post whilst doing a search, so you've probably had the answer for months now.
    Chuck Lyman
    Kansas City Chapter
    • Bruce B.
      • May 31, 1996
      • 2930
      As strange as it might seem, the windows are stamped both on the same side.
      Therefore when you install them, one will be stamped on the inside and the other on the outside.
      • Peter R.
        • June 19, 2011
        • 233
        Hi Chuck, Thanks for the reply. I discovered what Bruce said, i.e., they only stamped quarter windows one way and they went on either side of the car. I ended up getting all new, dated windows when rebuilding my '57 hardtop. Not an easy job, rebuilding hardtops, but it turned out very nice (thanks to a helpful NCRS member I corresponded with as I went and he helped me over any problems I encountered along the way).
        Pete
        Pete
        1954 Corvette #814
          Originally posted by Peter Rutledge (53439)
          Hi Chuck, Thanks for the reply. I discovered what Bruce said, i.e., they only stamped quarter windows one way and they went on either side of the car. I ended up getting all new, dated windows when rebuilding my '57 hardtop. Not an easy job, rebuilding hardtops, but it turned out very nice (thanks to a helpful NCRS member I corresponded with as I went and he helped me over any problems I encountered along the way). Pete
          Pete -
          C1 hardtop quarter windows and C1 door glass were released the same way - they were flat glass (Plexiglas for the quarter window), and there was no point in creating LH and RH part numbers for parts that were identical other than what side the logo was on. The door glass (as received at St. Louis) had LH and RH part numbers only because they were assemblies that included the LH and RH frames and sashes.
