I have a set of straight valve covers with no seam in them that I am trying to decide on the next step to correct an issue. The original valve covers were coated with a porcelain type of coatingand they have no seam on the casting.
1. I can try to have the coating taken off and see what the result is, OR
2. I have purchased a set of GM Performance Parts #3767493 valve covers new in the box that have the seam but also have very rough casting residue around the edges.
Do I file/grind the edges off the Performance Parts covers (why are they so rough?) and then try to clean the casting seam from them? Anyone have positive results with this seam removal?
Do I have the original ones blasted (sand, glass, other medium) and see how they turn out?
Other suggestions?
thanks
Other suggestions?
thanks
