Lock Washer; GM # 103328 - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7020
    According to the '66 AIM, lock washer GM# 103328 was used in a total qty=56 at the following locations
    Front Bumpers
    Rear Bumpers
    Radiator Support & Supply Tank
    Spring & Differential Mounting Bracket
    # 1, 2, 3 & 4 Body Mounts
    Steering Knuckle & Front Wheel Hub Assembly & Lower Control Arm Bumper
    Strut
    Crossmember & Suspension Attaching Parts
    It was also used during the C3 era at some of the same locations.
    Does anyone know the specs for this washer? Zinc? Or black phosphate? Grade? Is there anything that distinguishes it from a hardware store lock washer?
    Gary
  • Gary C.
    Administrator
    • October 1, 1982
    • 17665
    Re: Lock Washer; GM # 103328
    Gary, info from 1982 P&A 24 on washer # 103328 Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • John D.
      • June 30, 1991
      • 875
      Gary
      from the drawing - 7/16" Washer heavy helical spring lock. Carbon Steel SAE 1060 or Equivalent 38-46 HRC
      Finish plain- agrees with gray's chart above
      • Patrick N.
        • March 10, 2008
        • 954
        Gary,
        This lock washer is still available from AMK products http://www.amkproducts.com/Catalog_PDF/177-189.pdf, $3 for 20 pk, AMK part number B-1305 pg 187. The AMK and original lock washer share the same knurled texture on the outside flat of the washer- that is missing on the over the counter washers.
        • Gary B.
          • February 1, 1997
          • 7020
          John,
          Thanks for the spec. I think something is fishy with the table that Gary Chestnut posted. That lists the 103328 lock washer as having a 3/4" hole and a 1.19" OD, but that is too large.
          Gary
          • Gary B.
            • February 1, 1997
            • 7020
            Originally posted by Patrick Nolan (48743)
            Gary,
            Thanks Pat. The AMK Products washer sounds correct. In the AMK photo I don't see the knurled surface on 103328. But I think I know what you mean, but I think the serrations on the original GM washers are on the thin outer edge, not the nut-facing surfaces.
            Gary
            • Gary B.
              • February 1, 1997
              • 7020
              Gary,
              Patrick,
              PS. Yesterday someone told me the GM 103328 lock washers have a thickness of around 0.184", and that hardware store washers are 0.14". The 0.14" thickness is what is quoted for the AMK Products lock washer, so maybe the AMK washer is not exactly like the original 103228.
              Gary
              • Gary B.
                • February 1, 1997
                • 7020
                Originally posted by John Daly (19684)
                Gary
                John,
                Does the drawing list the thickness of 103328? I thought that the AMK Products lock washer was a match until I noticed the 0.14" thickness, which is less than the 0.184" thickness of an original GM 103328 based on what I was told yesterday by someone who had an original handy to measure.
                Gary
                • Patrick N.
                  • March 10, 2008
                  • 954
                  Originally posted by Gary Beaupre (28818)
                  Patrick,
                  Gary
                  I have found AMK to be accurate with the fasteners I have ordered in the past but anything is possible, I don't have one to measure but this would be good to chase down to find out what thickness is needed / spec'd. Might be good to call AMK to see what they say.
                  Best,
                  Pat
                  • John D.
                    • December 1, 1979
                    • 5507
                    Gary, I agree with you as there appears to be a typo in Gary Chestnus chart form the Standard Parts Catalog.
                    Notice it lists 3/8 3/8 3/4 7/16 etc. The 103328 washer is NOT a 3/4 hole.
                    Definitely an error on that chart.
                    Typical 7/16 split lock washers are .109 thick. Heavy duty are .133 thick. High collar split locks are .140 thick. Looking in MSC Industrial Supply .140 thick is the thickest they list. And to repeat the thick ones are called High collar. Finish on originals I have seen was bare/rusty. For your kits I think Zinc would be nice but that's your business.
                    Today's washers are not like yesterdays at all. On the FI units if I want to buy 1/4" split lock washers they always are too thick in comparison to the ones Rochester Products used.
                    Check McMaster Carr and see what they have. John
                    • Gary C.
                      Administrator
                      • October 1, 1982
                      • 17665
                      John, wrong or not GM had the same info from 1982 on in their P&A 24 Fastener books for lock washer 103328. Gary....
                      NCRS Texas Chapter
                      • Gary C.
                        Administrator
                        • October 1, 1982
                        • 17665
                        Gary, looks like the Parts Counter replacement is a 120383. P&A 24 #120383 is 7/16" Zinc with O/D 25/32, Medium (thickness). Gary....
                        NCRS Texas Chapter
                        • Gary B.
                          • February 1, 1997
                          • 7020
                          John,
                          Thanks for the thickness dimensions on the various types. I'll check what I think are originals tonight to see what I get for the thickness.
                          Gary
                            The inside diameter on the P&A chart has to be a mis-print; I have a slew of 7/16" split lock washers, and they all measure .444" ID.
                            • Rich P.
                              • January 12, 2009
                              • 1361
                              The original St Louis installed lock washers I have are all thicker and have squared edges, some are knurled most are smooth. They were unique and I always stashed them away when I could. Many new lock washers have more rounded edges. It may be as simple as finding a heavier speck lock washer for the current suppliers.
