'72 drier mounting brackwts - NCRS Discussion Boards
  • Tom L.
    • October 17, 2006
    • 1439
    While cleaning up my front end I removed the A/C drier (A/C not functional at this time). It was mounted on the outboard side of the studs on the inner fender. the AIM shows that it should be mounted on the inboard side. My concern is the brackets. The bottom one has a "leg" that stops it from slipping down. I'm fairly sure it is incorrect. Anyone know what it might be for or have any other comments? Thanks!!
  • Bill C.
    • July 15, 2007
    • 904
    Re: '72 drier mounting brackwts
    the one with the notched bracket goes in the upper position.
    The notch fits in near the sight glass
    the other bracket is on the bottom.
    • Tom L.
      • October 17, 2006
      • 1439
      When you say "noched", I'm assuming you mean the one that I refer to as the one with the"leg" shown in the bottom of the first photo and the left of the second. Correct?
      • Bill C.
        • July 15, 2007
        • 904
        yeah --
        I will look for a really good picture of the drier mounted.
        If you zoom in on the one I already attached, you can see the top of the notched bracket by the sight glass.
          • 6958
          Lynn, I took a look at my 72 A/C car, As Bill states the one with the leg is the top bracket ( You would think the opposite). This will put the brackets on the same side with the studs.
          • Tom L.
            • October 17, 2006
            • 1439
            Thanks, I didn't put it that way but someone felt the drier would drop out. Thanks!!
