1967 Upper and lower control arm torque settings - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1321
    To all,
    I have all the torque settings done elsewhere on these control arms. However, the manual states, as I read it, that there needs to be 20 lbs of torque on the bolts going into the bushings. Yet, I see that this "could" be 90 to 100 lbs. Can someone help me out to clarify this. It seems that 90 lbs on these bolts seems a bit much.
    jerry
    • 15646
    Re: 1967 Upper and lower control arm torque settings
    Originally posted by Gerald Coia (11656)
    To all,
    jerry
    Jerry,
    I can't help you with 1967 torque, but just posting a reminder to tighten these bolts with the suspension at "normal ride height" or you will put the bushings into a torque bind that can result in rapid failure of the bushings.
    • Bill H.
      • August 8, 2011
      • 439
      I don't have the manual for my 67 and the 68 chassis manual sucks.
      But the upper bolts are 3/8-16 (coarse thread) so the standard torque is 30 lbs.
      The lower bolts are 7/16 - 14 so, 50 lbs.
      The manual says torque after spring install but I agree with Terry - torque at ride height.
      • Ray G.
        • May 31, 1986
        • 1189
        Found these torques. Believe these are correct.
        Front Suspension:
        Upper A-Frame Bushing Bolt .........30 @ ride height........9/16
        Upper A-Frame Align, Shim Nut......50.........11/16
        Lower A-Frame Fr. Mtg. Bolts ........70.........5/8
        Lower A-Frame Rear Mounting......100........7/8 & 13/16 nut
        Steering Arm to Spindle ................70.........3/4 Nuts (63-68, 11/16)
        Ball Joint (upper) .........................45+........3/4 nut
        Ball Joint (lower) .........................75+........7/8 nut
        Ray
        I hope you dance
          The lower control arm bushing bolts are 45-55 ft-lbs (at design ride height, as shown in the Assembly Manual). There is no torque shown in the A.I.M. for the upper control arm bushing bolts, as they came into the plant already torqued (with the arm fixtured at design ride height); their spec is 40 ft-lbs, as shown in the "Specifications" section at the back of the Chassis Service Manual.
          • Ray G.
            • May 31, 1986
            • 1189
            Thanks John.
            Had the torques I posted in a file on my computer. I will correct them.
            Ray
            I hope you dance
            • Gerald C.
              • June 30, 1987
              • 1321
              I really hate to seem naive,but.....I still can't recognize the torque settings for the large short bolt that's on the top of the spindle and holds the backing plate and the top of the disc brake support. Also, the two lower bolts on the backing plate that hold the bottom of the brake bracket and the steering are to the spindle.
              Thanks for eveyone's feedback
              jerry
                jerry
                Jerry -
                The large/short bolt at the top is 75 ft-lbs. - it's called out as "Brake Anchor Bolt - Disc Brakes" in the "Corvette" column in the '67 Chassis Service Manual. The "Steering Arm Attaching Nuts" item in the "Corvette" column is blank - I think they intended that to be covered by the 75 ft-lbs. item (the steering arm attaching nuts for the other car lines run from 65 to 85 ft-lbs.).
                • Gerald C.
                  • June 30, 1987
                  • 1321
                  Thank you John!!!! Much appreciated
                  Jerry
                  • Ray G.
                    • May 31, 1986
                    • 1189
                    Hello Jerry;
                    When asked for specific bolt torque or proper sequence it is important to add the suggestion of studying bolt torque in general. Factor such as grade of bolt, new or used, and dry or lubricated certainly are factors in the stretching of bolts properly.
                    Please don't take this suggestion as an assault on mechanical ability. Just trying to be helpful.
                    Ray
                    I hope you dance
