72 LT1 radiator over flow hose clip - NCRS Discussion Boards
  • Rick M.
    • June 30, 1995
    • 74
    Anyone have a picture or can explain where the over flow hose clip goes on the radiator? Thank you
  • Paul O.
    • August 31, 1990
    • 1716
    Re: 72 LT1 radiator over flow hose clip
    Rick
    It is attached about midway down the Passengers side of the radiator where the tank and center tubes and fins are soldered together. The clip lock into the flange area at the connection of the 2 sections then the shroud goes over top of the clip to rad attach point. Hope that explains it do not have a photo of said but I should have.
    Paul 18046
      • 15597
      I remember a photo being posted in a similar thread before the board upgrade.
      • Paul O.
        • August 31, 1990
        • 1716
        Here is the post that you had some photos can see the tag but the clip is hard to see.
        https://www.forums.ncrs.org/showthre...iator&uid=6633
        Paul 18046
