About a month ago I talked about cutting one coil off of the tightley wound end of the front springs on this 68 to lower the high front end, this is how it came out, summer photo is before and winter photo is after cut front coils.
68 roadster springs cut (photos)
Re: 68 roadster springs cut (photos)
Hi Dan we never did come up with reason for it sitting high in the front, my friend has only owned the car for a year now so anything is possible, although the springs did look original and had tags on them but could not read the numbers.- Top
Hi Jim,
The pictures look like you corrected the problem. I wonder if there is a down side to cutting the spring? How much did you remove? Is your friend's car a big block or small block?
TerryTerry Buchanan
Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
Corvettes Owned:
1977 Coupe
1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
2003 Electron Blue Coupe
2019 Torch Red Grand Sport Coupe- Top
