Engine Builder in North Jersey - NCRS Discussion Boards
  • Brian K.
    • September 19, 2007
    • 174
    Can anyone recommend a reputable engine builder in Northern NJ? Just a stock rebuild 327/300....nuthin fancy.
    Thank you.
    66 Coupe
    66 Convertible
    2022 2LT Coupe
    67 Chevelle SS396
    67 XLCH HD Sportster
  • Kevin G.
    • February 1, 2005
    • 1076
    Re: Engine Builder in North Jersey
    Brian,
    Might try giving Pat Musi a call.
    Pat was nice enough to allow a group of us Central New Jersey members, take a personal guided tour through his facility. Quite a set up! (They do more then just race engines)
    • Ron G.
      • December 1, 1984
      • 865
      In my opinion one of the best engine builders anywhere is Tony File out of New Jersey. Many years ago my Dad and I restored the Peter Fonda 1965 396 coupe, now owned by Paul Sedacca and Tony did the engine. We did the engine and chassis restoration. Supposedly this was the first M22 car and first production Corvette with side exhaust. I was told the other day that he is semi retired, but occasionally does take on a job. If you need his contact info, I may be able to get it for you.
      "SOLID LIFTERS MATTER"
      • Edward L.
        • 278
        Thank you.
        Contact Pat Musi. He has all needed equipment in his shop and he understands the importance of NCRS requirements regarding the engine stamp pad.
        The main reason I took my last engine to him was that they will dyno the motor after it's assembled. This assures a good cam break-in and eliminates having to chase various fluid leaks.
        Pat Musi Performance
        48 Lefferts Street
        Carteret, NJ 07008
        732 541-1919
        Good luck,
        Ed
        • Brian K.
          • 174
          Thanks Ed & Kevin,
          I called Pat...$2500 flat fee & a little more for hardened seats....that's the ticket. I was rebuilding my front end, found the pan leaking a bit (no issues with this motor) and look what I saw. The cam bearing is squshing out the side!photo.jpg
          66 Coupe
          66 Convertible
          2022 2LT Coupe
          67 Chevelle SS396
          • Joe R.
            • May 31, 2006
            • 1822
            Brian,
            Don't go for the hardened seats unless you plan to pull a trailer up the Smoky mountains with your Corvette!
            Joe
            • George D.
              • August 31, 2000
              • 225
              Brian,
              What's list of what he's going to do for the $2500.00?
              George
              • Brian K.
                • 174
                George,
                New pistons, boring, tourqe plate hone, decking if needed (preserving pad), align boring, cut crank, resize rods, new cam & gears, 5 angle valve job. He said it was a flat charge for this type of job. Seems reasonable, no?
                He suggested the hardened seats if I wasn't adding any fuel additives.
                Brian
                66 Coupe
                66 Convertible
                2022 2LT Coupe
                67 Chevelle SS396
                • George D.
                  • August 31, 2000
                  • 225
                  Brian,
                  I would also ask what manufacturers are being used for the various components. Are they going to mag particle the block and heads. I would think the block should be squared if necessary. What about lifters, push rods, valve spring, balancing the rotating assembly, timing chain (I suggest roller)? We can talk more tomorrow at dinner. I'll bring a copy of what was done when I had my engine rebuilt.
                  George
                  • Brian K.
                    • 174
                    Dropped my engine off at Musi's yesterday...He's very nice (as they all were), it's family run and a really impressive shop. Some killer stuff in there.
                    66 Coupe
                    66 Convertible
                    2022 2LT Coupe
                    67 Chevelle SS396
