'67-9 BB closed chamber Aluminum heads exhaust valve dia. - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    I always thought that the exhaust valve size for #3904392 ('67 L88 and L89) and #3919842 ('68 and '69 L89; '68 to mid-'69 L88) was nominally 1.84" dia., and this seems to be backed by the P&A30 period catalogs which show a different part # for aluminum head exhausts, although they don't specify diameter. Square port INTAKE valves were 2.19" for both iron and aluminum heads.
    But A.Colvin's Chev-by-the-Numbers '65-69 says should be 1.72" (like the iron heads), and the description for one set on eBay can't make up their mind whether it's 1.72" or 1.88" [like the open chamber L88 heads #3946074]
    Checked mine (off mid-year '67 '842' castings) and seems to confirm the 1.84".
    Can I assume that Colvin & the eBay poster are in error ?
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: '67-9 BB closed chamber Aluminum heads exhaust valve dia.
    all closed chambered aluminum BBC heads i ever saw had the i.840 ext. valve.
    • Patrick B.
      • August 31, 1985
      • 2003
      The TRW part number for the 1.84 exhaust valves is S2614, but I have not been able to locate any. Any ideas on a source?
      Do you have to modify 1.88 valves to get them?
      • Dick W.
        • 10483
        Good engine machinist can cut the seats to fit. For maximum benefit the ports right under the seats need to be pocket ported.
        Dick Whittington
        • Clem Z.
          • January 1, 2006
          • 9427
          if you change to a larger exhaust valve in the aluminum head i would get a new seat installed because the seat used with the 1.880 valves are "venturi" shaped seats for better exhaust flow.
          • Patrick B.
            • August 31, 1985
            • 2003
            Clem and Dick--- I don't want to change the heads. I just want to get 1.84 valves to fit the stock seats on 67 aluminum heads. Any sources or does one have to machine 1.88 valves down to make a 1.84 valve these days?
            • Clem Z.
              • January 1, 2006
              • 9427
              looks like you will have to machine down some 1.880 valves. no one lists a 1.840 valve as i bet there is very little call for them
