Side Exhaust Pipes - NCRS Discussion Boards
Side Exhaust Pipes
  • Paul L.
    • August 9, 2011
    • 39
    Re: Side Exhaust Pipes
    I have another question. They offer 2-1/2" and 2" pipes. The 2-1/2" are listed for SB 64 & 65. The 2" are listed for 66 & 67. My engine is a 68 -327 and do not know which size to order. Where is this measurment? Is it OD or ID? I cannot tell if only the block was replaced or anything else. I do know that the Aluminum intake is original (numbers match) What I don't kow is if the exhaust manifolds were retained.
    Can you offer any help on this?
    • Michael J.
      • January 27, 2009
      • 7141
      I'm not sure about that. I don't know what size the '68 exhaust manifolds would be for a small block compared to the C2s. Anyone?
      • Joe R.
        • May 31, 2006
        • 1822
        #18
        Paul,
        I believe that's ID. What is the GM number of your exhaust manifolds? What are your plans for the car (flight judging or driver or ???)?
        Joe
        • William C.
          • May 31, 1975
          • 6037
          #19
          I assume the car is a midyear with a '68 engine grafted in. If the original exhaust manifolds were used, the ID of the manifold outlet is 2 inches for all smallblock '66 cars, sorry for my previous description as it applied to '65.
          Last edited by William C.; September 26, 2012, 02:21 PM. Reason: elaborate/correct
          Bill Clupper #618
          • Paul L.
            • August 9, 2011
            • 39
            #20
            The car is a 1966 Coupe with the L79 engine. (350 HP) The block is the only thing that was changed but I cannot be sure. I will get the casting numbers from the installed exhaust manifolds and post it later. My intended use for the car is to be a driver. (Keep 'em on the road). Eventually I want to replace these non-factory pipes with original style and I do not want any surprises when I bolt the new ones on.
            • Paul L.
              • August 9, 2011
              • 39
              #21
              The Left side casting number is 3749965 LH 7 GM
              The right side is 3747008 or 3747038 or 3747088 The second to last digit is illegible. then blow it is RH GM. This manifold has a place for the thermal tube to the carb but it is unused.
              • Paul L.
                • August 9, 2011
                • 39
                #22
                The exhaust numbers are 3747008 or 3747088 or 3747038 Second to last number unreadable (RH)
                The LH is 3749965.
                What does this tell me?
                • Clark K.
                  • January 12, 2009
                  • 536
                  #23
                  First, your car must be newer than a 1965 #10,000 to have factory-installed side exhaust. If the rocker panel molding hangers/brackets are cut off, rather than bent up under the car, it is still NOT definitive that the car came with factory-installed side exhaust. Many Sting Rays that have been body-off restored have had the original frame welds for those hangers ground away and painted over. It would then take a more thorough examination of the chassis to determine which exhaust the car was "born with".
                  Since a Sting Ray with side exhaust is worth more, everything else being equal, a LOT of them have had this option added, including mine. It is a big (78 pts.?) originality hit at Flight judging meets but I love the sound and they are stayin on!
                  -Clark
                  Last edited by Clark K.; September 26, 2012, 09:09 PM. Reason: clarification/correction
                  • Paul L.
                    • August 9, 2011
                    • 39
                    #24
                    -Clark
                    • Michael J.
                      • January 27, 2009
                      • 7141
                      #25
                      Paul, the VIN number will not tell you where the body was built. Look on your trim tag beside "Body". If it starts with an A it is AO Smith, with an S it is St. Louis.
                      • Marco H.
                        • March 1, 2002
                        • 218
                        #26
                        Paul,
                        As Bill mentioned, all '66 (and '67) small blocks used the same exhaust manifolds with a 2" outlet ID regardless of horsepower rating. However the cars equipped with automatic had exhaust systems with 2" pipes. 4 speed cars had exhaust systems with 2.5" pipes that tapered down to 2" where they meet the manifold / heat riser. I believe the chambers (muffler section) had all the same ID regardless of pipe size.
                        Hope this helps.
                        Marco
                        • Paul L.
                          • August 9, 2011
                          • 39
                          #27
                          The trim tag does indeed have the "S". That was an error on my part about the VIN No.
                          • Michael M.
                            • September 1, 2010
                            • 118
                            #28
                            Hi Paul, The head pipe, the pipe leading from the exhaust manifold, on a correct 66 car with sidepipes is 2 inches and then increases to 2 1/2 inches before it makes those two turns and heads down the rocker area. The earlier (65) pipes were 2 1/2 inches out of the manifold. If your manifolds are 66 or later then they have a two inch outlet. 65 and earlier, high performance 327's had 2 1/2 manifold outlets. They both fit on your block, so you can use whatever you want. If you're not having the car judged, or even if you are, you can use 2 1/2 manifolds and head pipes. The question then becomes, can you get a top flight with a 68 block and incorrect manifolds. I have a 66 L79 with an original engine and sidepipes added later on. When I replaced my rusty pipes and manifolds, I used '65 manifolds and sidepipes. I'm not judging mine, so it doesn't matter. Some cars get a top flight with added sidepipes, but I don't know about an incorrect yr engine (if you even care). Some others will know better. BTW, I bought the sweet thunder "quiet" sidepipes. They are anything but quiet when you jump on it but they are a little tamer when idling and when cruising at under 2500 RPM. They are factory spec except for some packing in the baffle area, as I understand it. The insulation keeps some of the heat from coming under the door as well. I thought they were very well made. I know I'm giving up some performance from the stock sides and even more from stock (for my car) through the rear exhaust. That's one of the reasons I went with the 65 manifolds and straight 2 1/2 inch pipes. I love the look and the sound, but sometimes I like to hear the radio as well. It hasn't lost anything performance wise. Someday, I'll do a body off and restore the original exhaust and then have it judged. Hope this helps you, good luck! Mike
                            • Paul L.
                              • August 9, 2011
                              • 39
                              #29
                              • Joe R.
                                • May 31, 2006
                                • 1822
                                #30
                                Paul,
                                One of the best ways to get information on this board is to poke the GM # into the search. I tried searching on 3749965, here's one of the threads that came up:
                                https://www.forums.ncrs.org/showthre...hlight=3749965
                                Joe
