Oops - looks like a broken engine mount bracket - NCRS Discussion Boards
  • Keith R.
    • August 31, 2001
    • 675
    Was cleaning up my frame this afternoon and noticed two cracks in the right upper engine mount bracket. What's the consensus - repair or replace?
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
  • Al E.
    • September 5, 2011
    • 313
    Re: Oops - looks like a broken engine mount bracket
    Keith,
    Replace it. Buy a new mount and grind and cut off the old one.. At lease you will know it is done right. Better now than on a long Sunday drive with Gina. A man can deal with a little car troubles.. but the wife may not be so comfortable. Hard to explain to a woman why the car failed..
    • Keith R.
      • August 31, 2001
      • 675
      You're right Al - gotta keep Gina happy! My only concern is making sure the new bracket is properly aligned. Wonder how they did it at the factory? Must have had a jig.
      Keith MacRae
      NCRS #36692
      New Mexico Chapter
      1960 290HP FI
      • Russ S.
        • April 30, 1982
        • 2163
        A good welder should have no problem welding this to return it to just as good and strong as a new one providing the entire crack is assessable.
        • Al E.
          • September 5, 2011
          • 313
          I am going to outline the old mount with a ReD marker before i cut it off so the old one will go in the correct location. I have the same issues on the right side.
          • Philip P.
            • February 28, 2011
            • 558
            Would you enlighten me is this the mount welded to the frame, I went out and looked at mine an nothing looks familiar. Maybe this is a different year.
            Phil
            • Paul J.
              • September 9, 2008
              • 2091
              Keith, use a white or yellow fine point paint stick. I keep both of these in my shop for marking pulleys, etc. Also, if you have a MIG welder this is a simple repair. While replacing the bracket is your best option, you can also just grind out the crack and fill it, if you wish.
              Paul
              • Keith R.
                • August 31, 2001
                • 675
                It's welded to the frame with a crappy weld job Philip. Lots of weld material surrounding the bracket.
                Keith MacRae
                NCRS #36692
                New Mexico Chapter
                1960 290HP FI
