67 strut rod bushing question - NCRS Discussion Boards
  • Keith B.
    • March 7, 2008
    • 928
    I am looking at buying four NOS bushings part number 3775762. I only have one parts book and it only goes to 1972. so it only list that one. i know in the latter sharks they got bigger. i can only assume these are the correct ones for my original strut rods.
    thanks
  • Scott S.
    • September 11, 2009
    • 1961
    Re: 67 strut rod bushing question
    thanks
    Keith,
    GM 3775762 is the correct replacement bushing for 1963-1967 original strut rods (up through 1974, I think), and is still available from GMpartsdirect.com, currently $15.70 each.
      Keith -
      If it matters, note that those replacement bushings have a steel outer shell; the originals didn't.
      • Keith B.
        • March 7, 2008
        • 928
        John what are you to do if you want it to be like the original?
          • 43250
          Keith------
          Forget it. There are bushings on the market which do not have the outer steel shell. I recommend that these NOT be used. The original bushings were vulcanized-in-place and, thus, the rubber was "bonded" to the strut rod orifice. With the replacement bushings without the steel shell, they are a simple press fit in the orifice. Use the GM bushings (or equivalent thereof) with the steel outer shell.
