72 ujoints - NCRS Discussion Boards
72 ujoints
  • Rick M.
    • June 30, 1995
    • 74
    72 ujoints
    Are the ujoints in the driveshaft and the halfshafts the same? Thanks
    • 11669
    Re: 72 ujoints
    No, they are not.
    Driveshaft ones may have grease zerks, halfshaft ones don't.
    Patrick
    • Gene M.
      • April 1, 1985
      • 4232
      Re: 72 ujoints
      Half shaft joints are a whole lot bigger than drive shaft's........
      • Rick M.
        • June 30, 1995
        • 74
        Re: 72 ujoints
        Should there be grease zerks in the drive shaft?
          • 43248
          Re: 72 ujoints
          Rick-----
          Usually, there are no grease fittings on original driveshaft u-joints.
          • Rick M.
            • June 30, 1995
            • 74
            Re: 72 ujoints
            Thank you that is what I thought.
            • Ron G.
              • December 1, 1984
              • 865
              Re: 72 ujoints
              The half shaft u-joints are not only slightly larger, but are usually seen with a raised boss on one side and sometimes have the name Spicer on them in raised letters. GM replacements are usually seen with a zerk grease fitting. The u-joints for the drive shaft are marginally smaller and have a depression in the center. I have never seen any originals with a zerk grease fitting, maybe an aftermarket, but not an original.
              "SOLID LIFTERS MATTER"
              • Ray K.
                • July 31, 1985
                • 375
                Re: 72 ujoints
                Rick
                The u-joints for the driveshaft have a bearing cup diameter of 1 1/16 " while the halfshafts use
                a bearing cup at 1 3/16" diameter.
                Ray
