63 T-10 tranny value - NCRS Discussion Boards
  • Jim S.
    • March 1, 1986
    • 1408
    This is a bit off topic , but I know you guys will know !
    My Neighbor just asked me if I was interested in buying a T-10 Tranny . He has no idea what it is worth and neither do I .
    He does not want it , but it came attached to a 327/340 solid lifter rebuilt motor he does want. It is supposedly rebuilt as well !
    The following are the markings I could find and as best I could read :
    MAIN CASE : T10D-1
    TAIL HOUSING : T10-7D
    GM 3813490
    10-2-62
    INSPECTION COVER : 9-12-62A
    BEARING RETAINER : T10C6
    I am going to take a wild guess here and say it is for a 63 based on the two date codes I found ?
    So guys, does he have anything worth something , and if so , how much something ?
    Jim
  • Tom D.
    • September 30, 1981
    • 2151
    Re: 63 T-10 tranny value
    This trans could be worth 400 to 900 bucks, or even more after a rebuild. One would have to look inside to nail it down. Does he have rebuild receipts? Depends who did the rebuild. (I did my first one myself in 1966, pushed it up into my '62 Impala, and headed out on our honeymoon one week later!)
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Tom P.
      • April 1, 1980
      • 1828
      The 63 transmissions (both T10 and Muncie) are a ONE YEAR ONLY tranny. The MOST siginficant feature of the 63 trannys is the front bearing retainer. It has a smaller diameter than the 62-earlier or 64-later trannys. Thus, the 63 trannys ONLY MATE to a 63 bell housing------------------again, a one year only housing.
      In my book, they are ONLY WORTH what someone will give for a correctly dated 63 tranny.
      • Doug F.
        • November 1, 1983
        • 322
        you can lways change the front bearing retainer to the large one and it will then fit the more popular bell housings
        • Domenic T.
          • January 29, 2010
          • 2452
          Doug,
          Unless it is a aftermarket retainer, the bolt pattern on the trans is different.
          DOM
          • Jim S.
            • March 1, 1986
            • 1408
            Cary, Tom and Dom,
            Not knowing the history on 63s, I did't know what you were talking about .So I did some searching on the archives and found out that the" 63 only" bearing retainer is only 4.175 inches wide, while the more common retainer is 4.675 inches wide .
            I asked my neighbor to measure his , and it is indeed 4.7 inches wide . So it appears that it has been changed to a wider bearing cover . It is still a T10 cover however, as it does have the T10C6 on it . For whatever that information is worth ?
            As for the rest of the answers , I guess it is only worth something to someone with a early 63 , and not much more valuable than a decent Muncie to most , if I am reading these answers correctly. I guess the best I can do for him and our members , might be to list it for sale in the drive line to see if anybody needs one .
            Thanks guys for all the input ,
            Jim
            • Ray K.
              • July 31, 1985
              • 375
              Jim and all
              If this T-10 transmission happened to have been installed in a 1963 passenger car ( Impala, Belair, etc. ) with a 409 cu in engine, it would have the larger front bearing retainer as well as the larger bearing. The 409 engines retained the larger front bearing as used in 1961-62 pass cars and Corvettes. All other 1963's, pass cars and Corvettes, used the smaller front bearing as previously discussed.
              Ray
              • Timothy B.
                • April 30, 1983
                • 5203
                Ray,
                If it's a T-10 D case used in 1963 even if installed in a 409 the front bearing is the small diameter.
                Jim, one thing you could find out is if it's a close ratio or wide box, the wide box has one groove on the input shaft.
                • Jim S.
                  • March 1, 1986
                  • 1408
                  Tim ,
                  I sent you a PM.
                  As to anyone else who cares : No Notch in shaft ,and reportedly a close ratio box with new bearings and synchros.
                  JIm
                  • William C.
                    • May 31, 1975
                    • 6037
                    T 10-C case is 1962 vintage, not 1963.
                    Bill Clupper #618
                    • Jim S.
                      • March 1, 1986
                      • 1408
                      Hi bill,
                      It Is a T10 D case with all the date codes in late 62
                      Jim
                      • William C.
                        • May 31, 1975
                        • 6037
                        That would be a nice piece for an early '63 car.
                        Bill Clupper #618
