Any help? I tried to wiggle it out but the outlet tube on the bottom right is holding me back.
'72 condenser removal
Re: '72 condenser removal
hood has to off the car - no way to get it out otherwise.
it also will help if you loosen up the core support bolts on the side, if you push it back a little towards the engine it will help getting past the headlight vacuum actuators.- Top
I've only had the car for about five years. As I go through different parts of the car I'm figuring it out. There are days that I've thought that who ever put big blocks in these thins was a real joker.- Top
