57 corvette restoration - NCRS Discussion Boards
  • Jerry B.
    • August 31, 1994
    • 416
    Im am in the process of restoring my car. I am in need of some advice on how to reattach one of the pins on the fender scoops. It is an original.
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: 57 corvette restoration
    JB Weld should work fine.
    • Jerry B.
      • August 31, 1994
      • 416
      Thanks Bruce, I have cosidered JB weld. Will it be strong enough to support a fastner? Can pot metal handle any type of welding ie silver solder?
      • Bruce B.
        • May 31, 1996
        • 2930
        Jerry,
        I think if you use the speed type nut (thread cutting) it might break off the JB welded stud.
        I believe silver solder is used for pot metal repairs but I think the chrome has to be removed from the area.
        I had a stud broken off on one of mine and I ended up just putting a dab of silicone on the back to hold it in place.
        Not correct but it works.
        • Jerry B.
          • August 31, 1994
          • 416
          Bruce, I will give it a try. thanks much
          • Steven B.
            • June 30, 1982
            • 3990
            Jerry, I had an extra that the stud was broken off during removal from an original car. I took it to a local jeweler and he did the repair.
            Steve
            • Paul J.
              • September 9, 2008
              • 2091
              Jerry
              The best way to fix it is to braze/solder it. I have used the following products with good success. There is actually a video somewhere showing them putting a stud back onto a console with these products (I believe Super Alloy 1). I use this with MAPP gas but it works a lot better with a tourch.
              Discover premium welding products, including rods, tools, and accessories at Muggy Weld. Shop now for reliable welding solutions!
              Paul
