What's the significance of the notch (or notches if multiple) at only one of the ends of a GM coil spring. There was a spring thread within the past few weeks, and the list of similar threads (at the bottom) suggested a post by Joe Ciaravino in a thread titled "C2 front coil spring", way back in May 2003. I see it's the last also in this thread. Click on the "similar" link at the bottom of this thread. Joe mentions the notch(es) having a significance in terms of how the spring is to be installed (without saying what, exactly).
Here's my spring/notch examples: First 2 pics are of my NOS spring in a GM box dated 1983; the (single) notch is at the bottom end (with the widely spaced coils). Other end has nothing.
Third pic is of (what I believe is) an identical part # spring (perhaps not NOS, manufacture date unknown) with two and a half notches, located at the upper end (based on closer spaced coils). Nothing on the bottom end.
So are the notches simply the result of a holding tool during fabrication, or are they added to help as a marker for installation ?
Reply
