Where do I cut seams in door weatherstrip and battery box seal in my 69 - NCRS Discussion Boards
  • Gary H.
    • June 8, 2008
    • 308
    I assume the seam on the door is supposed to be at the bottom middle?
    What about the battery door seal? Is the seam also at the middle rear?
    Gary
    • 3422
    Re: Where do I cut seams in door weatherstrip and battery box seal in my 69
    Hi Gary,
    On my 71 the seam for the battery compartment seal is in one of the corners. I don't know how typical that might be.
    The door weatherstrip seam was roughly in the middle.
    • Ron G.
      • December 1, 1984
      • 866
      As Alan said, the battery compartment foam seal is usually cut at the corners and the door w/s is cut at the bottom in the middle.
      "SOLID LIFTERS MATTER"
      • Reba W.
        • 938
        I agree with Alan's and Ron's assessment. I have seen a lot of door weatherstrip with the cut somewhere toward the door front and quite often, it doesn't meet.
