Ignition switch c1 1959 corvette - NCRS Discussion Boards
  • Trevor J.
    • June 2, 2011
    • 9
    C1 1959 CORVETTE
    Could somebody confirm if my ignition switch is correct in its operation.
    With the key out of the Ignition Switch and in Lock Position the switch cannot be turned.
    Put the key in the Ignition Switch in Lock Position, the switch will turn. But the key can be removed in all positions i.e. OFF / On / Start is this correct.
    So once you have used the key to unlock the ignition swithch you can remove the key and start and run the car without the key. The key only locks the ignition switch.
    Is this correct for Judging.
    Cheers Trevor (Australia)
  • Donald H.
    • November 2, 2009
    • 2594
    Re: Ignition switch c1 1959 corvette
    I not certain, but there was an article in The Fall 2009 Restorer on how to make a replacement ignition switch work properly. In the article it says "In 58-64 Corvettes, the key can be removed when the key is turn to the lock and on positions, but it cannot be removed when it is in the off position. Unfortunately, the current replacemnt switches allow the key to be removed when the key is in the all three positions." I've attached a scan of that page. Look like an easy fix.
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
      • 6960
      Trevor, My 63 switch works the same way, I believe this to be correct. once in the lock position and key removed is the only position you cannot turn the switch. any other position the key can be removed and ing. switch can be turned without key.
      • Al E.
        • September 5, 2011
        • 313
        Originally posted by Trevor Jones (53401)
        C1 1959 CORVETTE
        Trevor,
        I have a 1960, when I had the original ignition switch I could pull the key out while the car was running. But..I bought a new one and now I cant. I think.. that these switches get worned down at times and make it loose.
        This is the issues I had
        Al
        • Bill M.
          • April 1, 1977
          • 1386
          The NCRS PV Guide says that the '58-'62 key should not come out in "off", but wear will allow it to be removed. It will come out in "off" on my 100,000 mile '59.
            • 6960
            Bill, what is it that wears in the switch? do you happen to know? tumblers in switch ot the cylinder it self? Thanks Ed
            • Bill M.
              • April 1, 1977
              • 1386
              Ed: There is a bar on the side of the cylinder. If the bar is pushed, the key won't come out. Maybe there is a mating area on the switch that depresses that bar in the "off" position. That area on the switch wears and doesn't push on the bar anymore? I probably won't bother "fixing" mine. Bill
              • Trevor J.
                • June 2, 2011
                • 9
                Thanks Donald,
                Your information has helped. Judging next weekend here in Australia and we were concerned re this Ignition Switch.
                Thanks again from Australia. Wonderful web site and great members.
                Thanks again Cheers Trevor
                • Trevor J.
                  • June 2, 2011
                  • 9
                  Thanks Edward,
                  Judging this coming weekend in Australia and this was a small problem but believe it to be Ok. Thanks from us here in Oz Land. Great Web site and members thanks again Trevor
                  • Trevor J.
                    • June 2, 2011
                    • 9
                    Thanks Al, We are being judged here in Australia next weekend. A very first for our C1 and this was a small issue. See what the judges think at this point of time. Thanks for your time. Good web site. Cheers from Oz Land. Trevor
