paint removal - NCRS Discussion Boards
paint removal
  • Nick L.
    • January 30, 2012
    • 8
    paint removal
    Any technique that will remove paint and leave the textured finish on plastic interior parts ? C3, Years ago I painted the parts with spray can Krylon paint
  • Kenneth B.
    • August 31, 1984
    • 2087
    Re: paint removal
    What plastic parts are you asking about?
    KEN
    • Nick L.
      • January 30, 2012
      • 8
      Re: paint removal
      Hello, conv. top headliner, seat backs, plastic interior parts that have the leather look texture. thanks for reply
        • 11643
        Re: paint removal
        Walnut shells or corncob media (think rifle reloading) via low pressure blaster.
        I know one occasional (but well known) poster here who did this to remove black paint from interior parts and found a beautiful colored interior underneath.
        Patrick
        • Dick W.
          • 10483
          Re: paint removal
          Soda blasting at low pressure will do the same thing
          Dick Whittington
          • Ron G.
            • December 1, 1984
            • 865
            Re: paint removal
            You can try a towel with lacquer thinner on it, but doing a small section at a time. When the existing color is removed it would be a good idea to nuetralize it with simple green and water, a 50/50 combo. This method has worked for me in the past.
            "SOLID LIFTERS MATTER"
            • Scott O.
              • December 9, 2009
              • 100
              Re: paint removal
              Try http://www.citristrip.com/
              I used it and it didi not damage the plastic underneath. You can get it at Walmart
              Try in an out of sight area first to insure it does not damage the plastic
              Good luck, scott
              • Kenneth B.
                • August 31, 1984
                • 2087
                Re: paint removal
                I would remove parts from the interior & go with a low pressur blaster. Find some one that understands what you are trying to do as not to alter the original finish.
                GOOD LUCK KEN
