Tail light material - NCRS Discussion Boards
Tail light material
+ More Options
Posts
  • Roger B.
    • June 30, 1991
    • 82
    Tail light material
    Can anyone advise if there is a wiring materia made to covers tail light wires.
    It seems to be a woven material about 1/4" in diamater.
    Thanks in advance
  • Dick W.
    • 10483
    Re: Tail light material
    It is called fabric loom. It is available from many suppliers. One is Del City Wiring
    Dick Whittington
    • Roger B.
      • June 30, 1991
      • 82
      Thanks dick, i see your responses often.
      Thanks again
      roger
        • 43287
        Thanks in advance
        Roger------
        Do you mean stuff like this?
        • William C.
          • May 31, 1975
          • 6037
          My former employer did not make the stuff, but purchased ir from an available source. Wiremold strikes my memory, but a search for asphalt based Or impregnated) loom might turn up some sources.
          Bill Clupper #618
          • Mike E.
            • February 28, 1975
            • 5152
            A fundamental problem with this thread---61/62 never used that kind of material anywhere but for the temp sending wire. Tail light wiring was simply black plastic wrapped with a gray cone over 62's and nothing over the socket on a 61.
            • Roger B.
              • June 30, 1991
              • 82
              Mike, do i understand that just black tape was used on the tail light wiring coming from seat area back to tail lights?
              thanks Mike for info.
              Roger
              • Dick W.
                • 10483
                Thanks again
                roger
                Fools names and fools faces often appear in public places
                Dick Whittington
                  • 43287
                  Mike------
                  Yes, the temp sender wire insulation is the only place that I've seen it used on Corvettes, too, but my familiarity with C1 Corvettes is very limited.
                  • Mike E.
                    • February 28, 1975
                    • 5152
                    Absolutely correct, Roger!
                    Roger
                    • Philip P.
                      • February 28, 2011
                      • 558
                      And it is not black electrical tape it is black wrapping with litlle or no adhesive at least that is the way it was in 1960.
                        • 43287
                        Philip------
                        Yes, that is usually the type of material that is used for wiring harnesses on Corvettes right through at least 1982. It is available from Dr. Rebuild and, likely, others.
