Brake Fluid Identification - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1299
    I just drained the brake fluid out of my m/c on my 1967 non pb car. My question is "how do I tell which type of brake fluid I have"? I appreciate any guidance.
    Jerry
    • 43250
    Re: Brake Fluid Identification
    Jerry
    Jerry------
    All you need to know is if it's a glycol ester based fluid (DOT 3, 4, 5.1) or a silicone based fluid (DOT 5). All glycol ester fluids are compatible.
    Take some of the fluid you have and place it in a small glass jar. Fill the jar about half full with the fluid and fill the rest with water. Shake it up and let it sit for 15 minutes. If after sitting if the fluid in the jar is completely mixed and homogeneous, then you have a glycol ester-based fluid. If there is a phase separation (two distinct layers like oil and water), then you have silicone-based fluid.
    • Gerald C.
      • June 30, 1987
      • 1299
      Joe
      Thanks!!!
      Jerry
      Jerry------
      • Gerald C.
        • June 30, 1987
        • 1299
        Joe,
        It mixed so it's glycol ester-based. Does it make a difference in which one I use....DOT 3,4,5.1?
          • 15616
          Joe,
